1 - 10 of 10 Posts
im happy to belive if we can get an order together for 5 or more units the price will start with a 6 !
who wants one,really wants one,and wants one now ??
fits direct to 5,wiring diagram with it for 6
form a queue
What will it bring me
how much boost does it give me
my car does a lof of fuel cuts so i must be running close to 1.1 bar lately
Hi,
I had fuel cuts and the problem was the wastegate had rust in it.
I change it for a new one for around 160£ but it's normal steel and looks bad quality,
but I haven't found a replacement one for standard turbo.
Anyway when you fit a free flow exhaust and air filter your boost pressure is higher,but it should not fuel cut.But if the wastegate is damaged,it will raise the boost too much for the standard ecu.
The ralliart sports ecu works perfectly,it doesn't turn up the boost by itself,you have to do that with the restrictors or a electronic boost controller.
But it allows you to turn up the boost with no fuel cuts and the improvement is there.
I would be interested in one but not right now!
I want a Motec M 48.
I also want a Bozz Speed turbine kit TD 05/06 and HKS full exhaus w/ Hyper Muffler and aluminium turbo and coolant hoses and a triplke disc clutch and and air intake box and pistons and con rods etc.
mouton
I want the same ECU as Jerry RA420996R1, if this is same one your talking about count me in!
Regards Dave
yes correct part number
ill be happier when im absolutely sure of these wiring mods for your 6,s
im working on it !
1 - 10 of 10 Posts
