1 - 5 of 5 Posts
any ideas on how to check this as sometimes it works and sometimes it don`t think its reading correct its ben changed to miles at some point
not really fussed as its showing 57000 so not really losing out am i lol
What model EVO are you refering to mate? My VIII had a problem with the speedo and it was the signal conversion box that converts the km/h to mph. This sits on top of the gearbox and it basically filled with water causing it to short out.
If you refering to a VI then the speedo convertor is located on the bulk head and fails in the same way mine did.
evo 4 mate if this helps
it worked again today
probably going to go back off as usual though
Sounds like it will be the same thing, i.e. the Speedo Conversion device. I'm not familiar with the EVO IV so not entirely sure. Do a search as there has been a few with similar isues.
1 - 5 of 5 Posts
