Selling 2 SPA Dual gauges and A-Pillar for an Evo. Recently removed from my Evo 7.
Black face black bezel.
Oil Temperature
Oil Pressure
Water Temperature
Boost
Switchable 7 colour backlight
Adjustable backlight brightness
User programmable settings for pressure and temp i.e. PSI, BAR or KGcm2, C or F
High resolution modes for 0.1 PSI or C etc
Programmable button function, recall and menu etc
Extended temperature operation for extreme climates -20 +70 C
Stainless steel pressure and vacuum sensors
Programmable warning lights, including low battery
Programmable outputs for driving external LEDs or relays
Programmable high and low alarm settings for both pressure and temperatures
Contrast adjust for easier reading at different viewing angles
All work perfectly, loom is a bit grubby but works fine.
Oil pressure sensor has died, but a brand new one is provided, will just need to be wired into existing harness.
Cheapest i can find these gauges alone is £410 for both.
https://www.spa-uk.co.uk/Product/Turbo BoostOil Pressure Gauge (DG217)
£300 Delivered.
Oil Temperature
Oil Pressure
Water Temperature
Boost
£300 Delivered.
