Guest
·I have been observing the ap 6 pot setup (wich i have myself) and the movít setup if you see both sets which the big differance is that the whole brake system is place more inside the wheel if you want to do this you get a bell which must fit over the hub the bell now used in the standard setup is almost flat we all know someting flat will bend far better than a bell in trapezium setup.
so my guess is if you can make a bracket wich sets the brembo caliper 1 cm to back so you can use the standard ap 330 discs and then place the caliper 2 cm to inside of the wheel let someone make a bracket and a bell and youre brembo problem is my opinion solved.
regards
andre
regards
andre
