Hi all hope you can shed some light on a problem that has started today. When turning right and turning steering back to the left there is what i can only describe as a snatching/grabbing on the N/S of the car. I have heard of top mounts cluncking but i have only had mine replaced 2 weeks ago. Any thoughts??
Andy
Andy,
I may be totally wrong on this, but as you'll see from my "Accident Damage ?" thread, some muppet hit my car, other muppets believed that they could fix the problem by doing a wheel align.
Anyway, getting to the point, my car now seems to do what you have described.
I don't know exactly what the cause is but I suspect it may be a bent track rod / rack , damage to the rack itself or just bad geometry.
I would recommend getting the car properly aligned by someone competent. If you've changed the topmounts, this will almost certainly have altered the geometry.
Cheers,
Simon
Had the car checked out. Looks like its the front struts. Ordered 2 new ones. Will let you know the outcome when i have had them fitted.
Thanks for your reply
Andy
Had the struts fitted today. Car now sorted. No more snatching/ grabbing or knocking at all.
