1 - 11 of 11 Posts
Guys,
I fitted a slim lime fan today, obviously pretty simple. Fan works tried it on a direct power source.
Wiring, just used spade connectors for now, S didn want too remove oem plug.
Left engine runing for 15-20 mins too ser if kicked in, but nothing. Air con fan comes onthough. Is the one in oem rad a secondary unit?
Wiring is too the module for ran fan etc.
Any ideas?
Yea, both are connected did not disconnect the larger of the 2, just the small one with black an blue wires.
Just curious if this should. Come on, as car was running for the best part of 35 mins after taking for a drive, an temp did not move over the reg position. Just a bit confused as re connected the plugg too oem fan an thzt didn do anything either. Ac fan was going tho
Yea controllers still in, an yea its strange as the air con fan come on is that meant too?
Which fan did you swap, you sure you havnt changed the ac fan by mistake and so the normal rad is working and you think its the ac one?
The large fan unit, on the back of radiator near the oem intake. It was plugged into a little control unit, black an blue wires.
Wired into the control unit using connectors.
Dan
1 - 11 of 11 Posts
