1 - 3 of 3 Posts
Is there any other way I can fit evo 8 coilovers to my 6 with out paying 100 pounds for shims there must be :wallbang:
There is no easy way really, first you need 2 shims per side as the Evo8 have a wider upright that coilover fits around so shims make up gap, you can make them easy enough if your good with a drill and saw, but you also need to sort out the bolts as they are larger diameter on the later cars as well.
Most people redrill the hubs and use the Evo8 larger bolts, or you can make some small top hat inserts to go into coilover and take up difference when using Evo 6 bolts, i had this on my Evo5 with E9 bilsteins but if i was to do it again would drill out hubs for larger bolts as more solid setup.
Here is a kit Rosssport do if you havent already seen it - http://lancerregister.com/showthread.php?t=411985
Ian
1 - 3 of 3 Posts
