1 - 5 of 5 Posts
can some1 write a full article on fitting and setting up a sard fpr please. preferable for a viii or ix. also as a pressure guage is needed can anybody suggest a good (and cheap) place to buy one as i cant borrow one from anywhere and dont wanna pay a fortune to only use the thing once.
cheers
in advance
sean
you can get a gauge for a little as £10 just go to a hyd or pneumatic dist and ask for a 0>100psi 1/8 back entry 50mm face
hope this helps as for setting up just remove vac pipe and adjust till you get the correct pressure if you need a step by step your best bet is to get someone to fit it :(
mike
that scool mate cheers. am waiting for new car to be delivered and the pump fpr to arrive so will have a look at it all when it is here. i am sure it is str8 forward, i just wanted a bit of a heads up first off all.
being stuck out in germany makes it a bit hard to "just pop into a hyd or neu dealership and pick up a guage though.
1 - 5 of 5 Posts
