1 - 11 of 11 Posts
Discussion Starter #1
Hi there, I'm about to buy a Sard FPR for my EVO VI and I don't know the correct fitting size for it. Do I buy the -6AN or the -8AN fittings?
And what about the Type R one, do I need it or can I stick with the basic model?
Thanks for the help.
Ipe
Discussion Starter #3
moses said:
mate u dont need a type r i use the standard sard one and always did even with 700 bhp
type r is very good its mostly for very high powered evos and skylines mainly like over 750 bhp above
or even 700
make sure u get an adaptor too to fit
i will give u the part number
No. 69010 sard regulator
Thx Moses. What is the adaptor size that I need? I know that there are the -6an and the -8an sizes, but I don't know wich one to get.
gonna get one as well (more than likely from moses) to put on my ix.
perhaps when you guys fit yours you could write some notes on the installation and setting up.
perhaps with a few pix thrown in along the way?
mate when u are fitting it give me a shout i will ask mark shead to help u via pm how to fit it, like i said to u via pm, its best fitted by a guy who fits these all the time, its sad i know u are in germany at the mo and u dont have anyone their to do it, u need to do it yourself
fuel regs are a messing business if u aint used to fit them
you need to determine what size fuel hose dia it is 6mm or 8mm which will tell which fitting you need.also weather you use screw type fitting on the feul hose or normal push and jubilee clip
zia
an6 my friend is the PART NUMBER 69011
and also for the bigger type rj which is available for both fitments
just reading my catalogue and also
thats not the one we fit on evos
its 69010 for the reg 8=
an6 connector is too thick but small of course , its wider where the 8 is longer and thinner
adaptor part number is the one i gave u
No.69018SRA05
reg number 69010
this one for the evos the ones we use in mostly all the cars in this forum
give them the above part numbers and u surely wont go wrong
u will get a reg, 2 connectors standard by sard and an adaptor is separate your supplier will get u that too
and then i just been told today while speaking to mark the 3rd connector which sard dont send u, u need to find an exact size from your local fitter and fit that to your adaptor
if he is on later i will ask him to help u guys on how to fit it
agrabau u using a type rj even on that u can use either an 8 or a an6
66mm x 92mm the wider reg
then the sizes for part number 69010
are 50mm x 96mm and the smaller one
1 - 11 of 11 Posts
