1 - 2 of 2 Posts
hi i got a standard evo6 at the mo building up parts. until then i jut got a hks ssqv dump valve since fitting the car does go as well in second but go es better in third why! is it because its dumping to atmosphere my boost is ok !.2bar on the gauge or isit im used to it had it a year :rolleyes: :eek:
Your original dump valve may have been leaking and letting boost pressure disappear. Now you've fitted the HKS, the boost doesn't leak and you're running back to normal again.
Andy
1 - 2 of 2 Posts
