1 - 18 of 18 Posts
· Registered
If it's an inline filter (I think most are) then a clogged one will cause lean running, due to not being able to pass as much fuel through. You'll notice it top end first as that's where the highest demand is.
I don't think they are either that expensive, or that difficult to replace though, so it's a fairly simple "fix" just to replace it regardless :)
PS I have never changed a fuel filter on my Evo so I'm no expert on the matter though ;)
· Registered
thanks for the link and advice too guys - basically the car has felt like it has been hesitating like f*ck for a while now, i put this down to plugs but they are less than a year old but i ruled them out, but we are gonna try and rule out the easy ideas first - see if that helps
· Registered
I'd get some diagnostics done on it before you start changing stuff.
Get a fuel pressure meter stuck on the end of the rail, get a wideband lambda stuck on the car and get the behaviour analysed, then go from there, as the nature of the lean running will indicate which direction to persue the problem
· Registered
Mine was hesitating like hell after I had a boost controller fitted. I took it to WRC Tech last week, it was running dangerously lean between 3k & 5.5k, luckily Chris spotted that the pipe had been knocked off my fuel regulator. :eek:
All is well now. :D
1 - 18 of 18 Posts
