1 - 2 of 2 Posts
I've got a set of rods and one looks to have spun a bearing on a previous build, got discolouration at the bottom of it. Had it checked at work and according to the machine it's 0.062mm out of round, checked another rod which hasn't spun a bearing and that was 0.054mm out of round.
Need to know if this is within tolerance or not?
You've got to check all 4 of them, torqued up to spec.
They're always out of round after they've been used.
That one (both actually) is miles out.
Best just to get another second hand rod, or two.
See how the other two compare?
1 - 2 of 2 Posts
