1 - 3 of 3 Posts
Been working through why my reverse light is not working found everything ok up to the gearbox where the connector isnt onto the reverse light switch. The car has had a different gearbox in it and it looks like the connector for the reverse light switch is different to the one on the loom (if its the right conector I have found). Is there a difference in connectors between any of the 6 speeds? didnt want to go shorting the plug out to check incase I popped something else shorting out the wrong plug lol It may be i've just not looked all round the loom still not stripped the battery tray etc out to look, just the wire comes out the loom at the perfect location for the reverse light switch... 2 and 2 together...:shake:
There are differences between 5 and 6 speed connectors
Post a pic of the switch and connector, I'll try and advise further
Wire colours should be - red and brown
thanks, i'll post a pic up tomorrow, are the wire colours the same just the plugs different?
1 - 3 of 3 Posts
