1 - 13 of 13 Posts
Advise please guys took these out looking to cure a slight high rpm misfire (6500)
I would have thought the car is running rich I installed nevereverman fuel pump hard wire kit and not been mapped just yet
Automotive tire Household hardware Nickel Auto part Composite material
Auto part Household hardware Engineering Electric blue Cylinder
Im not sure about rich unless its been sat idling, but have you gapped them? 0.55mm i think is recommended on standard wasted spark arrangement.
Gaps are too big if you're running big boost mate.
There standard size gap boost is set at 1.3bar will be mapped at 1.5bar so. 55mm is recommended?
Sent from my F5121 using Tapatalk
Yes it is.
Whenever I ran more even with a COP kit, it misfired.
Reactions: Evo87
Yes it is.
How bad was your misfire mine only in high rpm boost does not seem to affect too much
I have exactly the same problem as you at the moment, getting it looked out to find out what's causing it
If you find out what could be the cause do post what was causing it
I see slight misfire around 6.5k doesn't seem to matter what boost level it's set to
Mine was usually on boost ramp.
Between 3.5-4.5krpm.
Spark blow out.
Have had it happen high up though.
If it's still happening despite lowering the boost, it could be your coils breaking down.
Can you try someone's coils on your evo?
Is the pump hardwired?
Should get it mapped asap to make sure the pump isn't leaning the mixture at high rpm.
My walbro did that until it was hardwired.
Spark blow out.
Tested my coils have 17mohms resistance all good compared them with my e8 coils and pump is hardwired have tried 2 walbros one was suspected fake
plugs all look good colour but gaps do look good. Its the cheapest test for a misfire. New set of NGK plugs with 0.55mm gap. (i used NGK BPR8ES, ask Neverneverman on here as he can supply, as can most of the traders i guess) Ive had misfires in a few of my evos and a set of plugs, gapped correctly, sorted it. You'll pay around £12 for a set of NGK. Don't waste the money on the £60 iridium ones. No point IMHO.
Thanks buddy I have the BPR8ES in there now have not gapped them I will be doing that next hope it cures it although it's not as noticeable with the new plugs
1 - 13 of 13 Posts
