https://www.etsy.com/shop/CUTMENDSWAP?ref=seller-platform-mcnavEtsy link?
If you can wire in a set of gauges you should be OK!Im not good with wiring!
Exactly my problems!!! we can just sit and dreamWANT WANT WANT - but I don't trust myself to do electrical ****e... Plus I can't afford it at the moment...
Yes you can the reveltronics forum has guides on how to tap off existing sensors and calibrate them. https://forum.reveltronics.com/viewforum.php?f=3Can you get it to read the values off the factory sensors direct from the ecu, or do you need to add additional sensors?
Sent from my SM-G930F using Tapatalk
it comes with 2 digital temp sensors the you have to solder up. they are intended for indoor outdoor temp but the evo has that already. i used cheap ntc temp sensors and removed the guts and thermal glued them inside you can see the pic of the 2 sensors on page one. you can also tap off existing sensors. i planned to use the oem temp sender but had an extra digital one laying around so decided against that.Does this come in a kit with sensors and/or can it use inputs form existing sensors?
If you were in the UK, we would all be off around your house :lol:Yes you can the reveltronics forum has guides on how to tap off existing sensors and calibrate them. https://forum.reveltronics.com/viewforum.php?f=3
Probably to demand a refund . . . . :smthumbdoIf you were in the UK, we would all be off around your house :lol:
I literally don't understand your posts.Probably to demand a refund . . . . :smthumbdo
they are in English :wallbang:I literally don't understand your posts.
must be an inside joke I guessthey are in English :wallbang:
I meant so he could fit ours/mine!Probably to demand a refund . . . . :smthumbdo
Don't bother as the OP is clueless about calibrating sensors etc :thumbdownI meant so he could fit ours/mine!
where are you getting this from?Don't bother as the OP is clueless about calibrating sensors etc :thumbdown
Your idea of sharing ECU RTC signals with third party productswhere are you getting this from?
Never seen any legnum/galant vr4 have any issues over on https://www.ozvr4.com/threads/utcomp-installation.15828/Is it a good idea to piggy back off the factory sensors already fitted to the ECU without the risk of disturbing the reading ?
lol you should give me an example then. I had this setup running in my MR2 turbo for years with no issues. granted the only thing that was intercepted was the injector pulse but still, 65K miles with no issues.Your idea of sharing ECU RTC signals with third party products
BIG Mistake![]()
