1 - 20 of 27 Posts
You will get a CEL shortly unless you disable the fault in the ECU or swap to rom ID 99270000. The sensor gets warm as it's heated, so make sure it's not touching anything.
Ive disabled the rear O2 using ECUflash. :smthumbup
I put a plastic bag over it to stop it getting covered in crap! Will this melt off if i dont remove it? :eek::confused:
Did you do the periphery mod or change the rom to 99270000? Will probably get hot enough to melt a plastic bag.
No, I will look for the rear O2 heater circuit CEL disable in the periphery bits, so you can remove the sensor with that rom also.
1 - 20 of 27 Posts
