1 - 8 of 8 Posts
Im going to get my rear calipers refurbed...advise needed.
When i take them off is there anyway i can crimp the brake fluid pipe that goes onto caliper , then but back on when finnished. Just to save be bleading and putting new fluid in as the fluid thats in at mo hasnt been there for long.
Cam - i clamped the hose with a proper set of clamps, that sorted that one out, and when i took the caliper off, i took the bolt out, put a large nut with the copper washers on it and wound it in, seemed to seal it nicely :) I hope that helps
Steve
i think this was posted up before for if you have braded hoses as you cant clamp them but apparently if you jam the brake pedal down this will stop the fluid draining out the system, probably easiest wedging something between the pedal and the seat to hold it down.
cheers mark
yep, gunna have to bleed it anyway mate if you remove the caliper.
anyway... NEVER short cut with brakes is my motto.
As already said Craig, if you've got braided hoses fitted then these can't be clamped as you will damage them internally.
I've got several pairs of Snap-On hose clamps, but their only suitable for rubber hoses, but work well.
Your going to have to bleed them anyway if you disconnect them.......
Get yer wallet out again. Ain't Evo ownership brilliant :crackup:
1 - 8 of 8 Posts
