Hi all had a quick search but not found the answers.i need to check and adjust the tps on a evo 6 as having stalling problems since removing throttle body to fit new throttle spindle seals.
I have evo scan but can't see or find where I can get tps voltage up or is it in code reader bit or mut II section. Can someone point me in the right direction please. Also is there a idle control valve that needs setting up
12% is that when engine warm or doesn't matter just checked mine and think mine was on 33 % which mine is ok it's my dads evo 6 which has the problems
Thanks all sorted now. Mine was 13.3 % not 33 lol but the other car was at 18 so adjusted that and a lot better thanks
