1 - 2 of 2 Posts
Could someone please tell me if there is any special way to re fit the release bearing so it is clipped in to the cover plate or will it clip in as soon as i operate the clutch?
clutch refitting
when you get the box bolted to the engine pull the clutch relese arm in the direction of the slave cylinder (against the spring) it should click into place. lever should then be roughly in middle of the slot in bell housing.
1 - 2 of 2 Posts
