1 - 5 of 5 Posts
I 've got the three gauge kit under the stereo hole.
I'm not sure whether the temperature gauge is water or oil. Does anyone know?
It only has deg C, no other indication. It only gets up to 70 C during normal driving and takes ages longer than the cluster temp gauge to register anything!
P
could be the under the collar temp. guage! goes up as the sul goes down. ;)
Pondy
I have the same kit. It is an oil temperature gauge. It's surprising how long the oil takes to get to temperature compared to the water gauge. Usually takes about 6 or 7 miles of steady driving. You will see it go higher if driving hard.
Dave
Oli
The gauge kit is a whopping £463 |PLS| VAT. Looks nice in the car though and looks as if it should be there, rather than added on. The other gauges are voltage and boost. It's a mechanical boost gauge, but at least on my car is very accurate. I recently compared it to a professional gauge when the car was being tested and it gave the same readings.
Dave
1 - 5 of 5 Posts
