1 - 14 of 14 Posts
Having my SARD fitted tonight, whats the best pressure to set it to to be safe, ive got it booked in for a fueling check on the 5th of April, i wont be running over 1.4 bar until then
think ill drop it down tonight then, would i not get a huge amount of flames if i was getting bore wash?
I got my SARD 2nd hand from a member on here so cant really help with where to get one
yes m8 doesn't change much when you put it back on though
It should drop quite a bit with the vac pipe on :confused: .... mine goes from 42psi down to 36psi... which may not sound a lot but every psi makes a big difference to fuel supply....also dont have it set too high as bore wash will cause serious damage to your engine. HTH
Ian
Not necessarily. If you've got too much fuel, it may just dribble out the exhaust and not vaporise enough to actually ignite.
Andy
1 - 14 of 14 Posts
