Well, the standard setup has reasonable (not TOO soft) damping but the suspensions wont last. Simply too small and dual tubes... When you jump over small hills on back roads, they will not damp enough, springs will compress so that all the springs touch (if you know what I mean) and the sar will absorp the rest, which is obviously bad for it. Plus they are annoying to use, very spongy and losing a lot of stiffness over a very short period of time. Too much roll as well. This is, once again, due to the fact that they are dual tube technology dampers (MAXI and blade, this is the correct English term, I looked it up!) in small diameter.
