Guest
·I found the Dynamic shock absorber which I had fitted and set up a month ago to be less good on the right hand side, and there was also a strange noise once in a while. I checked it out and found the front left shock to be leaking oil! The hose going from the shock absorber to the separate gas container was cut into by a small ring on top of the spring. I had Proflex shocks fitted immediately, the gas containers come out of the very top of the shock, so nothing can get trapped there. The handling is much better, too. A lot more progressive, better absorbing.
