Guest
·Maxi, as promised, here are my settings after I had the shorter springs fitted in the back:
Camber front: 2,3 degrees
Camber back: 1,75 degrees
Front and amp; rear high speed bump: 6 clicks
Front low speed bump: 12 clicks
Rear low speed bump: 14 clicks
Front and amp; rear rebound: 12 clicks
I really need some shorter springs in the front also, as the ride height was lowered about 15mm all around and was only achieved by taking the helper springs out. It's not a problem as the springs were fastened to the top mount, but would be nicer with the helper springs. It does grip really well (pulls your fillings out your teeth!). I'll set it up properly when at Cadwell Park on Friday, as making the suspension harder in everyday use is very painful for my back.
P.S.: I still kept the reservoirs mounted to the strut brace, no other place.
