1 - 9 of 9 Posts
hi every body just joined and wondering i have a evo 6 gsr with full exhaust sistem mushrom air filter rallyart ecu avcr bost controler walbro fuel pump hard pipe kit what kinde of power should i get:handsup::handsup::handsup:
hello and welcome. without knowing to much my guess would be approx 340-350bhp possibly? i dont know to much about the ecu but i would hazzard a guess at that
340 give or take 10.for your own piece of mind take the car to a recommended tuner and have the afr's and boost checked.if there is a good rolling road near you get a power run done and that will tell your how your car is running.welcome and enjoy
It'll completely depend upon what boost level you are running it at.
With that setup you should be able to run 1.4-1.5 bar and see around 350ish bhp however it is always wise to get the fuelling checked using a wideband lambda sensor after modifications to make sure everything is OK.
Oh and welcome to the MLR :beerchug:
1 - 9 of 9 Posts
