what kinda of oil used for power steering on E4?! is it dexron 1/2/3, mercon 1/2/3 or those off-the-shelf power steering fluid of any make?! seems light reddish in color but at the MIN level on cold check this morning, kinda worried tho'. not sure what oil is currently used but can i top it using other kinda oil without flushing out the existing one, is this ok/normal?!
sk-evo4,
Manual specifies ATF II (automatic transmission fluid)
I have used this on every vehicle I have serviced (not just Mits) without a problem.
If u think the fluid has not been changed for a while then it wud b good 2 change it anyway.
thanks for the info evoboy but is Dexron II or Esso ATF D ok?! what about Mercon II?! can different make of ATF mixed since i'm just top-up the oil?! kinda confused with all these jargons...
