1 - 18 of 18 Posts
Evo VI RS
Last weekend I attended the rolling road day at TRL and my car achieved 293.6 bhp at the fly. A good starting point.:D
My plan is to increase this figure in stages and I'm looking for the most power efficient, cost effective modification plan. The fewer mods i take to get where I want ultimately the better.
Right now my car is more or less standard. The same day as my rolling road I had a Kakimoto cat back exhaust fitted. The car already has a Greddy boost gauge, however for some weird reason the wires have been cut (I traced the wires from the engine bay to where it has been cut as the wiring enters the car at the door grommet)?! I have no idea why it's been cut! The car has not been remapped and does not have any kind of boost controller fitted. I fitted an APS BOV when I bought the car.
For my next mod I'm looking to buy a TSL firestorm 3" downpipe and decat. At this stage I would like to buy an induction kit but unsure which one to buy. I've heard rumours that the HKS mushroom type filters are bad. Is this true and why is this? I also like the look of the metal Blitz cone filter kits. Do I need to relocate the battery in the boot for this mod?
What next ????:confused:-
More boost - I plan on fitting ARP head studs and some form of boost controller whether it be a MBC or an electronically controlled boost controller. I would like recommendations for what type of boost controller to use.
More fuel -
Pump -Uprading to a walbro 255 lph seems good enough for now. Injectors - I assume stock injectors are adequate until I upgrade the turbo? Fuel rail - see injectors
Tune - I'd like to get this right the first time. I really fancy learning how to tune my car myself, in a real world, on road scenario. If possible I'd like to learn these skills from a reputable tuner. If this ins't possible I'd like to learn off an MLR buddy or teach myself.
I know AMS in America achieve excellent results without the need of a standalone EMS by reflashing the OEM ECU. What software do they use to do this and can I use this on a E5 ECU? If the V ECU is no good for this what is THE best upgrade? What OEM ECU's can I swap to. Is this a waste of time what stand alone ECU is best to use? AEM EMS look good. I know they are a massive company that achieves awesome results in the tuning world. Linking an AEM EMS to AIM seems like a big plus too. Motec, Autronic etc I know nothing about.
Other modifications to fit in at some point-
Clutch - probably a twin plate exedy
Cams and vernier pullies - I'm thinking 272's something like HKS or GSC's and HKS verniers.
Intercooler - What is best for an Evo V? Do I buy off the shelf like the likes of a GReddy or having one custom made buy someone like Norris?
Ultmate goal when I have loadsa dosh
Turbo kit - Ultimately I'd like to work towards fitting a turbo kit. My kit of choice would be an AMS turbo kit. The choice between a 30r or 35r is a very tough decision. I like the idea of the 30r because of the noticeably faster spool. I prefer the idea having the power of the 35r but the higher spool is off putting as is the need to fully forge the engine to support this power.
Rods pistons, stroker crank - Manley and Ross and some form of stroker.
OK these are my thoughts.
Anything else I'm missing?
I'm really looking for advice for the structure of this modification route - stages if you like.
Any advice or comments welcomed.
Many thank
Karl :mitsi: :thumbup:
The 3" downpipe and decat will be a good start. Once you have those done, I'd fit a high pressure fuel pump, boost controller and have it remapped. This is a fairly standard route to follow when tuning any turbocharged car. Getting a nice large cold air feed to the stock air box (with high flow element) will help here too. At this tune level, the stock air box will be your best bet induction wise as it will flow enough air and keep it cool too.
Uprated head bolts are a waste of time and money at this level of tune.
From there, you could add a set of more agressive cams. These will allow more air/ fuel in and more exhaust gas out. You'll need to have the map tweaked to suit these.
At this stage, you may want to get the rods and pistons swapped for forged items as you risk bending things at this torque level.
Once this is done, you can add more boost and max the turbo out. This again will require a map tweak to suit.
Then it's new turbo, stroker kit, intercooler etc, etc...
You'll probably want to get the clutch swapped out for a high clamping pressure replacement at the cam stage.
Uprated brakes and suspension should be an early consideration too...
Paul
what u need to decid is what power u want at the end as this will decide what route to take if going over 400bhp u will need to uprate your rods
also will u be doing the mods or will you be useing a tuner
if useing a tuner then talk to them as they will no what will take you to the power level you want
john
Forged Rods/Pistons
9 Turbo
Uprated 272 cams
...and you will go like a bomb in an RS, rememebr 400hp in a lightweight RS will feel different to a lardy 400hp 7/8/9
Think about better brakes and some good coilovers, no need for more than 450hp IMO.
Forged Rods/Pistons
9 Turbo
Uprated 272 cams
Whats yours like Jim at 410hp on the IX tubby? Much better than with the stock turbo?
the 410/390 is with the 8mr tubby Steve, getting car back next week, forged, twin plate and 9 turbo so ill put up some results, Andy Fox will be mapping it, if I can collar him that is :rolleyes::D
Not too bothered about figures but I suppose im hoping for 430/430 with the boost pushed up there :thumbup:
Ah right, cheers :smthumbup
We have very similar specs. I too am hoping for that power/torque, cant wait to have it all fitted and mapped :naughty:
Evo VI RS
Discussion Starter · #8 · (Edited)
Paul
Coilovers will be fitted very soon ;) I'm holding out on the brakes for a while.
What level of tune are head bolts suitable for?
When you say tune, do you mean remap the ECU to suit mods. Is the stock V ECU suitable or do I need to uprade?
Evo VI RS
Discussion Starter · #9 · (Edited)
john
I will be fitting all modifications where I can.
I'm not in it to chase numbers. I want a systematical approach that I can mod in stages and stop when I feel I have enough. There is such a think as too modified and I don't want to go past the limit of enjoyment ie a real handful that's scary not fun. I also want to keep the car reliable enough to be daily driven.
Evo VI RS
Forged Rods/Pistons
9 Turbo
Uprated 272 cams
I think I'd rather go for a proper turbo kit that **** about with a 9 turbo.
I would only fit rods and pistons when I need too and I doubt I'll need to until I approach 400 bhp & 400 torques.
Like I said I'm looking to buy coilovers before anything else. Brakes can wait for now.
If you want a "proper" turbo kit then a good set of brakes are a must IMO, because the good old brembo's aint gonna stop you for long.
Ps; don't write off a nice 400/400 in an RS, look how Gav aka' Knoxville compares with his sprint times, against more powerful cars., because of the power to weight ratio its much more like nigh on 500hp car.
And if ytour gonna buy a big turbo, then unless you forge the car, your gonna be limited to what you can push out of it.
Food for thought.
Evo VI RS
Food for thought.
I'm sure the fact that Gav is a **** hot driver has something to do with it too ;)
Thanks for the advice I will bare everyones opinion in mind :smthumbup
Aswell mate, you said you didnt want it to be scary and a handfull. Having it forged/strokered and then strapping a big turbo kit (GT30/35) to an RS is defo gonna be scary and a handful! :eek:
It obviously depends on your budget aswell, what route you go down.
I bought the car with stage 1 mods; 3" turbo back exhaust, HKS filter, walbro pump.
First batch of mods, I had fitted; GSC S1R cams, fidenza pulleys, an Apexi boost controller and had it mapped by Matt @ TRL to approx 1.65bar. I never got a rolling road printout for this as his rollers were playing up at the time of it; but it is supposedly 380-390hp.
Then got a bit worried about flooring it incase one of the rods decided to go, so had the Norris Designs rod upgrade including a Cosworth headgasket and ARP Headstuds.
The car didnt really produce the power I was hoping for last weekend @ TRL though, and Matt thinks the stock intake pipework and HKS mushroom style filter is very restrictive. So I have just ordered a huge K&N filter, 3" alloy intake pipe, battery relocation kit, IX 80 series turbo, FP 950cc injectors and a Megan turbo elbow. With these fitted and another map tweak, and I should be hopefully around 420-430hp :naughty:
Yeah I read about that lol. I'm sure if I run it within it's design spec it will be a good turbo and will make the RS fly like the wind... (especially if I stroke at a later date! ;))
OK so what do I need to run a FP Red? Help please.
Rods
Pistons
Headgasket & ancillaries (headstuds, bolts, etc)
Cams
Pulleys
Springs and retainers
Induction kit with intake pipe
Bigger front mounted intercooler and hardpipe kit
1000cc injectors
Tubular Manifold
Turbo elbow
Boost Controller
All fitted & a remap :smthumbup
1 - 18 of 18 Posts
