1 - 11 of 11 Posts
hi everyone :)
has anyone had/heard the full turbo back power engineering exhaust including the sports cat?
a sound clip woud be ideal :D
im thinking about buying one and wanted to know how it sounded?
thanks
chris
I had the single exit pipe version on my old car. Wasn't a full system, just cat back. Was a very well made exhaust. Quite loud though. Louder than my HKS Hyper Muffler, but not as loud as a Blitz.
Here's a pic
I have the EV75 catback on my 6, and even with the original cat still on it's loud. I suspect the full turbo-back system will rival the Blitz for noise to be honest. As DaveGs pic shows it also follows the oem exhaust tunnel so you don't actually lose any ground clearance either (handy if you're in a dense speedbump area like me). ;)
It also means it's not as straight as some of the other exhausts like the 5Zigen or Blitz, which could in theory cost a bit of top-end power (although that's probably only true if you're running over 400bhp in my opinion, since the 2.5" oem manages 300bhp without any problems).
I don't think I've got the kit to make a sound clip, although if you're thinking of coming along to the RR day at Silverstone on the 9th you can have a good listen there :D
Ive got Dave g's old system and its a very nice exhaust. very well made,the welds are spot on ,a very nice sound at idle and on full power without being stupidly loud.
And again as Numptyscrub said you can still go over speed bumps without it catching.
Dunc
thanks alot for the replies everyone :)
really appreciate it
iv done a quick search and one owner of the turbo back system found his sport cat melt :eek: so i think il knock that on the head
will the pe downpipe fit onto the standard cat or will i have to buy a decat?
also how does the exhaust look when looking at the rear of the car because i have the hks super dragger fitted at the moment and the pipe hangs down enough for it to look terrible
so i was looking for an exhaust that tucks the pipe work up neater or buy something like a blitz that scraps that bend all together
any comments please
thanks again
chris
Hi Chris
If you are stood behind the car the exhaust comes out straight.
Im not sure on the downpipe,but i have a decat and then the pe pipe.i would have thought that their downpipe would match up to the standard cat but ring them just to make sure.
the pipework is tucked up high and looks nice and neat.
I'll try and get some pics at the weekend so you can see.
hope that helps
Dunc
thanks again everyone :)
has anyone got a pic knealing down behind the car please?
i ask because i have a super dragger at the moment which takes the same path as the pe i think and i dont like how low the piping hangs, low enough to see when following behind it.
also how does the blitz compare, i know this takes a more direct route,
will i have clearance problems owning an extreme (comes standard with lowered suspension)
thanks alot :)
chris
thanks alot dave thats exactly what i was after :D
its definately better than the hks i currently have but i think it probably still hangs low enough for a following car to see, and thats what i wanted to avoid
it does look like a quality exhaust though
is it possible to buy the system as a true 3" diameter system if i bought the downpipe and decat as well or does it taper down at the cat in all their systems?
has anyone got any similar pics of the blitz please
thanks again dave :D
chris
1 - 11 of 11 Posts
