please help as it is the compression of each cylinder of evo VI
C colorss · Registered Joined Apr 15, 2005 · 8 Posts Discussion Starter · #1 · Apr 15, 2005 Only show this user please help as it is the compression of each cylinder of evo VI
O oli goon · Registered Joined May 17, 2001 · 1,605 Posts #3 · Apr 15, 2005 Only show this user are you asking what pressure you get from a compression test on an evo 6? or what variance is allowed between cylinders?
C colorss · Registered Joined Apr 15, 2005 · 8 Posts Discussion Starter · #4 · Apr 15, 2005 Only show this user I asking what pressure you get from a compression test on an evo 6....my turbo is new and wategate an only 0.7 boost.
RaeTurbo · Premium Member Joined Nov 23, 2003 · 4,782 Posts #5 · Apr 16, 2005 Only show this user Around 175 lbs per square inch and should not be less than about 150
C colorss · Registered Joined Apr 15, 2005 · 8 Posts Discussion Starter · #6 · Apr 16, 2005 Only show this user only 120 per cylinders is bad?...... the loss cause compression is the lack of power in my turbo?
