1 - 20 of 45 Posts
Niiiiice mate :D
What is the spec of the engine? Also are you using RS diffs etc?
very nice mate :smthumbup
whats the full spec then?
bumper looks great with the square plate mounting :D
Discussion Starter · #20 · (Edited)
2.4l Full Forged Stroker Kit
Machining & Preparing of Cylinder Block
Balance Shaft Eliminator Kit
Full Race Engine Bearing Set
HKS Metal Headgasket
Cylinder Head Race Porting & Polishing
Piper Camshafts
HKS Cam Vernier Pulleys
Dual Valve Spring Kit
1mm O/S Stainless Steel Inlet Valves
1mm O/S Inconel Exhaust Valves
TurboSmart Blow Off Valve
HKS Iridium Spark Plug Set
PT67
( Consisting of; RC600 Turbocharger, RC 3mm Thick Walled Tubular Exhaust Manifold, TurboSmart 48mm Wastegate, RC Downpipe, Kenlowe Slimline Radiator Fan + Fittings)
AEM EMS Standalone ECU
Apexi AVC-R Boost Controller
Bosch 044 External Fuel Pump System
(Consisting of Bosch 044 External Fuel Pump, Fuel Lines, 1000cc Fuel Injectors)
Exedy Hyper Twin Plate Clutch Kit
Custom Intake Plenum with 80mm Throttle Body
Custom Intake Pipe Kit
Custom Metal Flow Induction Kit
Custom Turbo-back Exhaust System
Custom Intercooler Kit
1 - 20 of 45 Posts
