Discussion Starter #1
Hi does anyone know the part number for brake pads for Evo 6 AP racing 6 pot and 4 Pot rears?
Just about to order some DS3000 and don't know the size numbers without taking off the ones on the car.
cheers
Mark
Matt - cant remember the pattern number off hand but one thing to bare in mind is that if u have the E5/6 330mm kit then it uses 17mm thick pads not the standard 18mm, so ur'll either have to buy the thinner pad (possibly limiting ur choice) or grind them down a bit like wot I had to :(
Darryl
Hi,
I know they are not the ones you are looking to buy, but Extreme have got front and rear DS2500 pads in their parts bin 'sale' section, although that never seems too cheap to me. :D
Its not quite straight forward (Euro rules!). The fronts are only made in DS2500, as the calipers in the 330mm kit are termed as road calipers. The DS3000 will be slightly better, but expect higher disc wear. Plus they may well squeal and give a lot of brake dust.
After all that, if you really want DS3000, FRP3054R DS3000's can be machined to fit. RRP is £193.84+VAT, machining is an extra £15- (allow up to 10days)
Rears are FRP218R for DS3000, RRP is £76.06+VAT.
Give Gavin at Co-ordSport (01384 216102) a call, deals for members, as always. :coolsm:
