1 - 20 of 36 Posts
:eek:i thinkg my cars drinking to much fuel on average i am getting 120 miles from a full tank which cost £40 i dnt push my car hard this is from normal driving why is it doing this ;-:)wallbang: please help ive had it remapped
Super Moderator
Jesus built my car
Two questions spring to mind...what evo do you have and have you had the lambda sensor checked?
wheres can i go 2 get it checked and what price will i be looking at.if it needs replacing will it effect my map sorry to sound dump
Lambda sensor only effect closed loop fueling, so map should be fine. You can check the output voltage in Evoscan, or use a multimeter it should be between 0.1 and 0.9v. New sensor is somewhere from £50 to £200 depending on where you get it.
Any garage with a multimeter can check the voltage output from it. Give Andy or Chris at TOB a call, sure they can help.
any pikeys nearby with petrol stealing kit? No?
Lambda check needed :)
Sensor is located on the left side of the exhaust elbow, you can follow the cable from it up to the rocker cover into a multiplug connector.
Sounds like u have a heavy rite foot :crackup: Saying that, I only get around 170 from a full tank :lol: Obviously it depends on how hard u drive her, most ive ever got from a full tank was just over 230 miles :eek:
1 - 20 of 36 Posts
