Guest
·out of interest and sheer boredom, how accurate is the outside temp sensor on the climate control? where is the sensor? is it effeced by its location i.e engine heat/ drafts etc. ?
just curious.
just curious.
Oh thats so easy ,............................ yawn.......................TJ |EQU| transmission joint , ie the drive shaft joint at the transmission or gearbox end , BJ |EQU| bearing joint , ie the shaft joint at the wheel bearing or hub/knuckle end .Original Post:
Whats the BJ and TJ? (It's not top and bottom joint as it doesn't make sense)
