1 - 2 of 2 Posts
well i replaced the ciol pack.. still the same problem.. i replaced the ignition amp thing next to the coil packs.. still got the same problem...
one set of coil packs is firing...
now the first problem i had was that the car would start then after 10 to 15 secs cut out wth the engine light flashing.. after ifound out the coil pack was not firing i assuemd it was that ...
the only other thing i think it could be now is the ECU .. but its bloody strange that one pack fires but the other dont..
is there anyway diagnostic ports on the early evo that i could check for any error codes or any other way to test the ECU ???
also where is the ECU located ? dont want to go ripping everything apart :)
thanks in advance guys..
1 - 2 of 2 Posts
