Guest
·I would like to know the normal oil pressure of Evolution IV. When Idle, the oil pressure is slightly below 1 kg/cm2 and when cruising, it's around 4-5 kg/cm2 and the respond of the rise of the oil pressure when open up throttle is quick enough. Is that a problem to the engine ?
I've installed Apexi Auto Timer with o2 and air fuel mixture monitor and I found that when the turbo start to work. The air fuel mixture always below 10:1. What's going on ?
