1 - 12 of 12 Posts
Hi Everyone,
I've noticed after 15-20 mins of driving the Oil Lamp Warning light is turned on,
Park the car and checked the oil level and its fine, someone told me that i should check the oil level the next morning before starting the car and i did, and the oil level is fine
but the oil warning light still on after driving for a few minutes.
have anybody experienced the same as this? what is the possible cause of this?
any input is greatly appreciated.
It may if you're lucky just be the switch but if its the pump and you keep driving it you will destroy your engine.
Mine used to flicker until I replaced the switch, been all fine for 18months now. I also did a pressure check just to be sure it was ok aswell.
Switch is simple and straight forward to change.
Cheers Aj
Cheers Aj
Hi sorry, what switch is that? do you have a pic?
does anyone know the partnumber of Pressure Switch ?
Thanks stu8, appreciated:smthumbup
I can look for the parts as long as i know the partnumber
I got mine from import car parts, quick delivery and no issues with them each time iv ordered. Was a simple fix for me , think the sensor was about £12 delivered.
Cheers Aj
1 - 12 of 12 Posts
