Just popped the air filter out on the 320 and noticed abit of oil in the air filter housing... Nothing major...
Turbo no the way out?
As mentioned , if the pipe from side of rocker cover was plumbed back into intake pipe after MAF (standard oem evo set up ) then id expect small hint/midt of oil residue .....but if you have no such scenario then .......id be looking at turbo as you said :thumbup:
Sorry to hijack but i have this on mine and have the breather connected, would i benefit from a catch can and would i need to connect both breathers from the cam cover cheers
You can have one pipe from side of block going to a catch can , and then return pipe from catch can to intake pipe after maf , less chance of oily mist then
I only had the pipe from rear of block (pcv valve ) hooked up to catch can when running on MAP based PFC ....not on OEM set up :thumbup:
