1 - 3 of 3 Posts
Hi guys, in changing fmic pipe work too one with a tial q unit with flange. Currently have a synapse kit on which is plumped into both the oem air intake, an also the fmic upper pipe. Obviously the upper pipe side of things will be sorted. Just wondered best way too bung the hole up on the oem intake until i fit the aftermarket 4" kit when i have my sd conversion done next saturday.
Regards
Dan
If you can't get ahold of a 25mm blanking plug you could try something 25mm in diameter- like a piece of broom handle.... not saying I'd do it personally, but I have seen it!
You could probably get away with using the old dump valve as a blank, theres not too much pressure on the inlet to worry about it opening and sucking in nasty stuff :)
1 - 3 of 3 Posts
