1 - 13 of 13 Posts
Discussion Starter #1
Woodcote automotive have offered to sell
MILLER OILS and amp; FUEL TREATMENTS for CLUB
Members at a Special Price!!!!!
OCTANE PLUS fuel additive 10x250ml £25.36
CVL ( race addititive) 10x250ml £43.47
CFS full synthetic engine oil 5ltr 10w/40 and amp;
10w/60 £28.10
CRX 80w90 semi synthetic gearoil 5ltr £20.90
CRX syth 75w90 full synthetic gear oil 5ltr £24.77
All these prices include VAT.
Only shitty side is carriage cost !!
£6.99 inc vat for up to 25kgs
1 litre of oil wieghs approx 1 kg
1 case of fuel additive weighs 2.5kg
FREE CARRIAGE ON ORDERS OVER £117.50 inc vat
( £100 exc vat )
YOU MUST MENTION EVO CLUB WHEN PLACING ORDER
tel 01606 836637
fax 01606 837558
e mail [email protected]
also Robin Longdon , our contact can give
technical help if needed . All credit cards
and cash greatly received.
I ve nearly got through my first case of
octane boost plus , at 17 mpg a tank dosn t
last long !!!!!. Its well worth the money .
I wonder what the CVL compertion boost is like, anyone tried it let me know .
cheers Richard..
I
Discussion Starter #4
I use Millers CVL [ competition valve lubricant ] all the time as it adds 3 octane points as well as being a valve lubricant designed to prevent valve wear/seat recession under extreme conditions.
I totally recommend it as my Evo runs sweet, no tappet noise even on start up from cold the only concern is you have to remove your cat as this will contaminate it, although it is designed for use with unleaded fuel.
Try ARE Ltd @ Farnham 01252 733202 as i buy it cheaper from them.
Regards Dave
Discussion Starter #5
dave
what price can you get it from Farnham ?
If you buy over £100 , at woodautomotive and avoid the postage bill
it works out at £2.53 for a 250ml bottle.
regards Richard
ps do Farnham deliver small orders ?
Discussion Starter #6
I've just been down to my local motor factor who has offered me Wynn's Octan 10|PLS| (the stuff that claims to add 4-5 to the RON rating) for £2.70 a bottle if I buy in dozens!
Steve.
Discussion Starter #9
Try adding 20% Toluene , dosn`t effect the cat plus gives far higher octane then any after market booster and amp; yes i do use it for track days !
Discussion Starter #10
Where could you get the Toluene?
I have tried oct boost .avgas.
I'll try most things if it helps the rating and isn't over the top price wise.
cheers
Paul s
Discussion Starter #11
Shorty - Hays Chemicals, various depots around the UK ,Poole, Greenwich, Luton etc.
You will need a van |PLS| hard hat and amp; safety goggles to be allowed on site to collect it , minimum order is 25 ltrs @ £45 inc of vat per 25ltr drum.
Have noticed the engine runs/revs smoother and stronger @ the top end .
Regards Dave
Discussion Starter #12
Hi Dave,
I was just wondering if you have taken the cat of your E6? Also do you notice a difference using the Octane booster? How do you use it, do you mix it with normal unleaded for an octane rating of 97 - 98 or with Super for a rating or around 100???
Regards
Steve
Discussion Starter #13
Steve
Yes I have removed the cat, for road use I use 1 x CVL to every 20lts of SUL |EQU| 100 oct.
For trackdays try adding 1 gallon of Toluene to the above ratio http://www.ltregister.f9.co.uk/graphics/tonguewink1.gif border|EQU| 0 align|EQU| absmiddle >
Regards Dave
1 - 13 of 13 Posts
