Here you go
Here you go
Manifold Nuts
MD050076 x 2 Plain Washers
MD165879 x 2 Nuts
MD092806 x 7 Self Locking Nuts
MD041192 x 7 Plain Washer
Manifold Studs
MD146938 Studs 10x28mm x 2
MD005317 Studs 8 x28mm x 7
Manifold to Turbo Fittings
MD132656 Bolt x 3
MD132933 Plain Washer x 3
MD132930 Nut x 1
MD132933 Plain Washer x 1
MD050075 Stud x 1
Oil feed Pipe
MF660064 Copper Washers x 2
Oil Drain Pipe to turbo Gasket
MR258477 x 1
Manifold to turbo Gasket
MD171220 x 1
MD171221 x 1 Sealing Ring
Cylinder Head to Exhaust Manifold Gasket
MD181032 x 1
Take your pick
Mike THE
Here you go
Manifold Nuts
MD165879 x 2 Nuts
Manifold Studs
MD132656 Bolt x 3
MD132930 Nut x 1
MD050075 Stud x 1
Oil feed Pipe
MR258477 x 1
MD171220 x 1
MD181032 x 1
Take your pick
Mike THE
@ Camskill
