· Registered
The air con motor on my car is making loads of noise! am i right in saying that you can just replace the end bit of the pump? just sounds like the bearings are knackerd.
Also i need new discs and pads! where shall i get them from?
· Registered
yes...the bearings can be replaced
- might also be worth doing the seals at the same time
....due to the fact that your pump is not compatible with current gases should you want to get a re-charge (unless the seals have already been replaced)
discs/pads can be bought from
e.g. Camskill www.camskill.co.uk
or [email protected] on here.....
or contact 'thetyrant' on here;
Ian is able to get 'carbotech' pads which are apparently excellent even for trackdays
