Nitrous on a turbo is tantamount to raising the boost... more oxygen in the mix to burn fuel with. Including the raising of intake pressure, extra force on the pistons etc. etc.
Given what I've heard and learnt over the last few months, the only use I can see for nitrous in a turbo engine is low end revs to spool a high capacity turbo up quicker to help eliminate lag (ie extra exhaust mass at pre-spool). That or button for extra boost if your setup doesn't include variable boost settings from the cabin.
If you want to try it, fair enough, just make sure the engine is mechanically capable of withstanding the extra stresses, or it may go bang.
From memory, Justin (Yellow5) has nitrous fitted to his Supra?, he may have a more comprehensive knowledge of the pro's and cons of fitting no2 to turbo cars.
Derek
