1 - 20 of 37 Posts
Just fitted my new steering wheel and removable boss. :)
Very good anti theft device. ;)
MLR Oldie
Can you still reach the indicator and wiper stalks while holding the steering wheel? The reason I ask is I fitted one of these to a mates Escort and the steering wheel now protrudes further meaning that he cant reach the stalks while holding the steering wheel.
What was involved in removing the old wheel and airbag etc?
No problems removing the airbag. Took about 10 minutes.
My AYC light is on as I run an RS diff and the ayc is removed.
I can reach the indicator stalk with the new steering wheel. It is further away but I have big hands. ;) If you have small hands you will have a problem. :p
The process in removing the air bag is quiet easy.
Disconnect the battey and leave it for about 5min.
Remove the two security screws at the rear of the steering wheel.
Then remove the airbag from the steering wheel. Disconnect the leads from the back of the airbag.
Then undo the large nut that holds the steering wheel in place. The steering wheel will then just pull off.
Took about 15 minutes in total.
Skeletor
I just pulled the AYC bulb out the dash ;)
Darryl
does the boss enable u to retain the horn? did u have to remove the clock spring?
Yes the horn works and it also comes with the leads to plug into the airbag connector so that the light doesn't appear on the dash.
I didn't remove any clock spring.
Skeletor
Skeletor
Hello mate, what make Boss is it, as ive got a MOMO BOSS and i have lost the horn and the air bag light is on to,,,,,,,,how much are they and where will i get one from thanks Dene :cool:
Dene the Boss is made by Works Bell.
It is called the Rapfix Ball Lock System.
The quality is second to none.
Give SUMO Power a call as they supply them.
John
is it legal to remove the air bag off a car i went to sumo other week looks smart they are using it as a racing wheel :D
Skeletor
What comes with the lead for the airbag - the boss?
1 - 20 of 37 Posts
