1 - 20 of 40 Posts
It'll be some kind if new reward scheme ****** where you get 1p back for every £1000 spent on fuel.
I'd be very surprised if they're introducing a new higher octane fuel.
Yes but raised octane = more money, Its already £1.30 a litre. And with evo economy it doesnt last long
Super Moderator
Jesus built my car
To be honest every quarter I get about £15-20 in shell fuel vouchers.
I get a set of Maxell T-120s.
I'm not sure they'll raise the octane. Shell have already been told off by the advertising bodies for suggesting that octane improves performance so if they did raise octane they'll have to rely on the public's incorrect assumption that more octane will be better for them. I'd rather not pay more money for more octane I don't really need.
I hope they don't change it too much as I have an SD remap booked in next Friday and I've already filled her full of the current V power...
I use card when I full work van up always get twenty to go in the evo for free so it don't cost to much to run as I only did 1000 miles last year if u add up money on car ladt year it prob cost me 10 pound a mile as I bought so many bits bobs i.e. Wheels etc crazy ay
Interesting, let's see what is revealed!! I always try and us Shell compared to Tesco's offering but having my nearest Shell a 50 mile round trip away doesn't help!
Can I run AvGas in my vehicle?
AvGas is short for Aviation Gasoline. AvGas is of interest to motoring enthusiasts because of its availability, octane rating and low price compared to commercial race fuels. AvGas might seem an obvious choice but closer study raises some doubt.
AvGas LL100 stands for "Low Lead 100 Octane". TEL (Tetra-ethyl-lead) is added to raise the octane. When used in a motor vehicle this fuel will leave a lot of lead deposits in the motor. 100LL has a high lead content (0.5 grams per litre), even higher than leaded race fuels. The deposits left when TEL(lead) is burned are corrosive and damaging to valves, valve guides, valve seats and cylinder heads. Lead deposits will also block oxygen(lambda) sensors and catalytic converters and foul spark plugs even after only a short use. Also, 100LL has a chemical package added to make it perform at high altitude, and that isn't the best thing for motor vehicle performance here on the ground.
AvGas is blended for large-bore, long-stroke, low RPM engines which run at high altitude. While AvGas' higher octane is useful, smaller-bore, shorter-stroke, high RPM engines will perform better on racing fuel or high quality octane boosters. AvGas has lower volatility so when used in proportions higher than about 40%, part-throttle drivability and cold starts may be compromised. AvGas has a lower specific gravity so it will require a change in air-fuel ratio calibration for the engine to perform at its best. LL100 is blended with a high percentage of aromatics causing reduced throttle response which is not an issue with an aircraft engine but certainly an issue in a high-performance automotive engine. These high levels of aromatics will also damage rubber components in automotive fuel systems such as fuel lines, fuel pump seals and injector washers.
The sale and use of AvGas is heavily-regulated. Most aircraft fuel dealers refuse to put AvGas into anything other than an aircraft fuel tank. There is a legal grey area that has some vendors willing to dispense AvGas into "approved" containers if they believe the end use of that AvGas is fueling an aircraft engine. This loop-hole is how some may obtain AvGas for automotive use. Because AvGas has no taxes and duties on it, use on public roads is illegal and if found could result in your vehicle being impounded.
Germans got it right, 105 octane available from pumps...
Bizarre reference to aviation fuel-why post this piece of ancient automotive history? No sane person would put this **** in their fuel tanks!
1 - 20 of 40 Posts
