1 - 9 of 9 Posts
Selling my brand new Atp turbos Garrett gtx3076r stock location turbo kit, full twin scroll design using original manifold and elbow flanges, twin flapper internal waste gate, dual roller bearing turbo, has the 4" inlet option. Capable of up to 650hp!
Steel braided oil feed line assembly with banjo at the turbo and at the cylinder head
-Oil drain gasket and bolts to attach to stock oil drain tube to the turbo
-Banjo bolt and crush washers to attach to stock rear coolant pipe
-Steel braided coolant feed line assembly on front of turbo
-(4) 10mm studs and nuts for turbo to manifold
-(5) 10mm studs and nuts for turbo to 02 housing
-2.5" compressor discharge elbow (replaces the stock 1.75" J-pipe and rubber hose)
Hi, I'm located in Ilkeston, Derbyshire, I can do that price delivered yes. I believe so yes there's a reducer with it, although for a turbo of this size an uprated intercooler would be needed to reach anything like it's full potential.
hello there is this turbo still for sale how much do you want,do you have the 4inch intake pipe or would i have to make 1 up thanks mike
1 - 9 of 9 Posts
