I'm searching for an working ACD solenoid unit (whole valve) for my 2006 Wagon Evo 9.
It has the RS diff so the pump is only maintaining pressure in the center diff. Hence just one solenoid at the pump.
Can an ACD solenoid from an GSR unit be used? Are they physically same solenoid? GSR vs RS?
Having problems maintaining pressure. It seems like the valve sticks inside the valve neck and doesn't move enough/build pressure.
So looking for a working complete solenoid/valve to replace my apparently faulty one with.
Have had mine apart 3 times and all 3 have the valve rod been stuck inside the neck.
