1 - 3 of 3 Posts
Vendor
As per title we have the below turbokits on special at the moment. Manifolds are on order (10 pieces) and I have sold 3 already. Proven to produce the same or more hp as any of the top kits currently available.
Offered at a substantial cost reduction based on our competitors........... be quick!!!
Costs as below;
ND GT3076R (Cast Wheel) £2775.00 + Vat
ND GT3076R (Billet wheel) £2975.00 + Vat
ND GT3582R (Cast Wheel) £2895.00 + Vat
ND GT35R (Billet Wheel) £2995.00 + Vat
ND T04Z (Cast Wheel) £3125.00 + Vat (Air con must be removed)
ND T04Z (Billet Wheel) £3295.00 + Vat (Air con must be removed)
Benefits from "the best in the business" Shearer headers and elbows, the rest is done in house at ND. The external gate take off angle and subesquent re-routing angle (if that option is chosen) is better than any competitor kit.
No gaskets to blow, as all flanges are face plate fitting. Has to be the most popular volume kit in the UK and Europe behind AMS (Which have had several issues over time).
The kits come complete and ready to fit using the best hardware available. They do NOT include a lower intercooler pipe or turbo inlet pipe/air filter as almost every car/setup is different. We can however make any of this to suit where required (Small extra charge applies).
Kit contents;
Shearer Fab thick wall SS header (Limited lifetime warranty)
Shearer Fab 3" turbo elbow
Shearer Fab screamer pipe or ND wastegate re-circulation
Shearer 3" Frontpipe (Only on E7-9 and not with T04Z kits)
Tial 44mm V Band wastegate
Brand new Garrett ball bearing turbo charger
Screw fit Goodridge water/oil feed/return hose kit
Slimline 11" rad fan & fixing kit
Highly durable quality fixings
Vacuum lines & heat management shielding
Any questions please email, PM or phone.
Simon
As an addition we have 5 x Koyo Evo 6 large capacity radiators in stock, which fit nicely with these and other tubular headers. Moves the top hose away from the manifold and increases both cooling caapcity but also prevents against stock radiator seal failure. Especially relevant when used hard on track!
Vendor
Pics...........................
1 - 3 of 3 Posts
