Hi all,
Just thought I'd post up how I did my new ICE install including all the features of a double din + rear camera + sub and amp. I'm by no means good at this stuff but thought it might help someone else out if they are doing the same thing and aren't really sure!
So here goes….
I purchased myself a nice looking double din Xtrons unit off ebay, it was going cheap and as my first double din unit I thought why not, I knew it wasn't going to be no Sony or top quality one but it had satnav/radio/usb/ipod/aux/dvd/cd and all the trimmings. Cant really go wrong. Installing was easier than I thought....
Taking out the existing trim was very easy and just snapped out, then all is required is to unscrew the bottom tray and the double din fits perfectly in that hole that's left (with a double din adapter cage mind you)
http://www.lancerregister.com/attachment.php?attachmentid=223369&stc=1&d=1361484238
The old unit came out, then wiring up began, I had already spent a while looking at the very comprehensive wiring diagram printed on the unit itself and tried to figure everything out. I had made previous mistakes on my old car where I hadn't put the amp remote cable to the correct one so the amp was always on and drained the battery.
http://www.lancerregister.com/attachment.php?attachmentid=223370&stc=1&d=1361485657
I then got to work on the sub and amp. I had a huge sub in an even bigger sound box and I just wasn't happy with the amount of space it took up (after already shortening the box for my previous car!)
http://www.lancerregister.com/attachment.php?attachmentid=223371&stc=1&d=1361485657
I had seen on this forum somewhere that a guy had made his own way of installing it and it got me thinking. My plan was to either bolt a solid thick bit of wood on the rear bracing behind the seats or bolt it down so that the back of the sub was in the cavity of the spare wheel. That space isn't used anyway as I have 18" rota drifts so it was a possibility plus that space packed with blankets might act like a 'sound box' anyway. I decided to go with the first option and bolt it on to the rear body.
So out came the drill, mdf was lined up and holes drilled. I also decided to keep the original back cover thingy just to smarten it up so used my trusty dremel to cut the shape of the speaker to allow it to poke through and to eliminate any nasty vibration that might occur with it being flat up against it.
http://www.lancerregister.com/attachment.php?attachmentid=223373&stc=1&d=1361485657
http://www.lancerregister.com/attachment.php?attachmentid=223372&stc=1&d=1361485657
http://www.lancerregister.com/attachment.php?attachmentid=223374&stc=1&d=1361485657
I was trying to cut corners here, I knew the rear seats would have to come off to bolt the wood on, I should have taken them off at an early stage which would have helped me no end measuring up the cover thingy, as you can see from the picture I got the measurements slightly wrong!! Not a major drama though as the mdf would cover this. I offered up the mdf to make sure it would go, I used bolts with nylon washers against the metal to counter any vibration I might come across (not being sure if it would make any difference or not anyway!)....
So here goes….
