1 - 15 of 15 Posts
hi everyone,
Here will be my diary of re-building and maintainence of my rally car for '09 rally season.
At first will show what was done just after last year's season untill today ;)
The body itself, was prepared (seam welded and roll cage put) like in 2000. Since then nothing was done by several owners. So in most of the places cracks apeared. Mostly around welding places, around front and rear subframes. Also there was unwelded importing places.
Sand blast tent ;)
Then painted all body. Used a lot of clear coat (dont know how to call) under arches to protect from stone scarps.
This part will take a looot of time... :(
Wirring.
Trying to cut everything what is unnessecary.
Complet wirring:
Have done fire extinguisher system.
2 nozzles through bulkhead and one 1 to the turbo area. Others will by in the cockpit.
Doing brake system. It is not finished yet. The part which goes to the back is not done. I can not decide - to put brake balancer or hydraulic hand brake in the middle. Or put them both togeher.
But everything will be aeroquiped.
One line for both front brakes
To the front wheel
Here is the place for balancer and the will be going to the back.
Also rised up the gear change lever for 7cm with aloy tubes.
Have changed oil cooler place. Original place was very unprotected.
Will be using stock cooler.
hey mate...nice work. looks like you get a fresh and clean car. rebirth. rust protection and new technic.
good luck for your races!! :smthumbup
your have a post limit (20)
become a full member here and you have unlimited posts!! :smthumbup
1 - 15 of 15 Posts
