1 - 17 of 17 Posts
A strange title I know.
If I accelerate up hard through third, fourth and fifth. If I back of the accelerator, my car makes a farting noise sometimes....now it never used to do this (before I started using Octane Booster)....is this a nice flame pretruding, or could it be something sinister?!?
thanks,
Matt
Its the Secondary Air System (SAS), do a search on the forum for more details.
With my original ECU I used to be able to replicate the fart down a slip road of the motorway ;)
Kyl3cook said:
cheers mate, is that a bad thing?
Nope
"If the engine speed is held above 4000 rpm for at least 3 seconds and you lift off causing a sudden drop in engine speed the SAS operates and you get a slight rumbling 'farting' sound from the engine."
It used to create a slight flat spot when I went back on the throttle, but thats not a problem now ;)
lee5 said:
I thought the SAS was more of a rumble than a fart noise, which on my car came from under the car ???
Lee
One mans fart is another mans rumble :D
lee5 said:
Span do you still get it with the autronics, as mine dont do it on the PFC ???
Its not a feature within the Autronics ECU, not sure of other aftermarket ECU's
Most of the guys with high power Evo engines have it removed.
Regards,
Brian
mine pops bangs and rumbles everythin is sound on it at the moment the evo was brought into being to be a kick arse rally car to pop bang and whistle its way throught the forestry kicking every1s arse on the way and it did mint
1 - 17 of 17 Posts
